Stairs Problem, steps are cutted
2 REPLIES 2
C.Utzinger
195 Views, 2 Replies
HI
Please Help.
Stair.jpgI have a problem with a stair (see attached image). The steps in de middle are cutted, why does this happen?
Kind regards
2 REPLIES 2
in reply to: C.Utzinger
how did you create the stairs? I've experienced a similar problem when creating stairs by sketch, although the risers look very low so it could be something to do with that?
C.Utzinger
Hi, yes I needed to do it by sketch. There are two different Radius und a straight part at the end. The risers are 17,5cm and the steps are about 52cm.
I solved it for the moment with three different parts (stairs), but it was a big workaround.
Kind regards
