Message 1 of 11
- Mute
- Permalink
- Report
Hi
I created a cast in place stairs. After modifying its shape I have the path direction in the wrong way. the path should be like photo 2 from left to right. I have the direction in the right way when I click on the stairs to modify it (photo 2). I deleted all the available path lines and created a new path for all the 3 lines. I still have the same problem. Noticing that All these readings are in Level F1 when I have a better reading on Level GF (photo 3). I have no idea what is going on. Did I modify the stairs in a wrong way? Is there anything I can do to fix it?
Thank you
