Stairs numbering - Floor drawings with sectioned stairs (only visible steps)
M_Perez
Message 1 of 9
M_Perez
I have a stair that goes several floors up, and I want to number it (from 1 to n for each floor).
Given that in each floor plan I see half of the lower stair and half of the upper stair and that the lower floor is higher and the stair has 2 more steps.
How can I have just the visible steps tagged?
I have just the visible steps from the lower stair, but all of the upper stair. How can I get rid off the ones in the red mark?
Accepted solutions (3)
Replies (8)
Message 2 of 9
You can't.
Message 3 of 9
aRcHiTeCt.JM
.... masking ??
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 4 of 9
M_Perez
I tried to mask them, but the mask affects the steps too. Do I have to create a contour for each number? (even if they are the same mask region) It is like plotting and then using Tippex... :(
In that case I find writing them manually safer and more or less the same effort.
How is it that Revit recognise the stairs coming from below (there works it perfectly) and not the ones the going up?
Message 5 of 9
You can create a line based Detail family and a nested Generic annotation family with a label.  Use a formula to append the number in the label so that it keeps adding 1 to the first number you enter when you dragging the length of the line based family.
Message 6 of 9
M_Perez
I guess there is no better solution. Thank you all!
Message 7 of 9
aRcHiTeCt.JM
... sorry @M_Perez ... we tried but REVIT sometimes is just like that...
... as you said:  writing them manually
... or masking them one by one..
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 8 of 9
Hi @ToanDN
Can you please explain how to use a formula to append the number in the label on the arrayed Generic Annotation (the number)?
Unfortunately, once you array the GA (number), the value can't be set for each of the numbers.
See attached image below:
Message 9 of 9
Here is the setting of my family, it works pretty well. The only 'con' is that you need to estimate the maximum number of steps of each flight, normally it should be less than 15.
