01:05 AM
Hi Everyone,
I hope you guys can help me fix the parametric array that I am struggling to fix. As you can see in my two attachments below. I Created Small extruded boxes and arrayed them with last and assigned array a parameter called NumberOfAccessiblePanel, I locked the first and the last with reference planes and assigned these as PanelOffset Parameter. I Locked the second box with reference plane to create PanelGap and also assigned PanelWidth to the first arrayed box. I want to change the L and still able to keep the array with no problem while changing the PanelGap and PanelWidth simultaneously. Can you please help me to solve this issue?
