stairs incomplete
stairs incomplete
omarqassem94
Message 1 of 10
stairs incomplete
omarqassem94
i have this problems in stairs its incomplete and just happen in Monolithic Stair why this happen and how can i fix it Screenshot (137).png
Replies (9)
Message 2 of 10
aRcHiTeCt.JM
... did you try to delete that stair and draw a new one to see if that keeps going on?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 10
omarqassem94
yes i do and changed the type
Message 4 of 10
aRcHiTeCt.JM
.... open a new project and try to draw just the same stair
... lets see what happens?
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 5 of 10
If I had to guess, I'd say it's Stair by Sketch with 1 Riser line missing.  Add a Riser line to correct.
...don't you have Warnings associated with the stair?
Message 6 of 10
Can you Edit the stair > Edit sketch, and show a screenshot?
Message 7 of 10
aRcHiTeCt.JM
... did you get a solution ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 8 of 10
Corsten.Au
Hi
possible errors / adjustments required to fix that are
1. Design issue
2. Stair path  ( you may customise stair path to suite the stair, the default path doesn't work all the time )
Corsten
Building Designer
Message 9 of 10
ahmedsherif-99
how to fix the design space issue?
Message 10 of 10
ahmadfiroozi000
I think your length and your distance from the first level to the second level aren't enough
you must extend your length.
