Stairs: how can I make my landings overlap the supports?
raphael.oertelWSUX5
raphael.oertelWSUX5
I have created an industrial type stairs with steel supports and steel grid landings.
Got the landings between and above the supports, but not overlapping the support (landing on top of support)
Does anyone have an idea how to get there?
RDAOU
@raphael.oertelWSUX5
Select the stairs >> edit type and change supports (Left and right)  to Carriage
raphael.oertelWSUX5
I works, but the support type changes to rectangular where I want it to be a steel C-profile (UNP).
I can't change the profile afterwards, or am I missing something?
RDAOU
Unfortunately carriage type stringers can only be rectangular; hence you either leave it rectangular and add a detail component of C UNP in section views or Model the stair without the OOTB stringers and add Beams separately
raphael.oertelWSUX5
Thanks, another workaround would be to add a floor that works as a landing. I think I can turn off the landing and keep the supports in the stairs itself.
