stairs dont arrive up floor level
mcankusmez
Message 1 of 19
mcankusmez
hello ı have problem in revit about stair when I draw a stair,stair does not arrive up floor ı dont see this Therefore, I dont do landing .ı share a picture and my project files Shall you help me please ? Also floor height is 300 cm.If you tell with record video its maybe good for me stair problem.png
Replies (18)
Message 2 of 19
Can you post a screenshot of your Stair's Properties?
...are you sure the view isn't cutting off part of the stairs.  I mean, there not enough room for a straight run from what I can see, so I imagine you are dong an L-shape.
Message 3 of 19
mcankusmez
Message 4 of 19
constantin.stroescu
First, I think it's problem with your stair placement, it will reach the second Floor somewhere outside the building....never mind , we'll try to build it anyway..
  • you have used a Stair by Sketch which is not finished . It has only 9 Risers out of 16. So you have to add another 7 Risers.
  • as I have seen your stair starts from elevation +20 cm not 0,00 so you have to change it to fit the floor top..
  • In my opinion you'll have to move the stair in another position and possible to increase a little the Risers height to shorten its length..
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/screencast/Main/Details/7...
Constantin Stroescu
Message 5 of 19
Why can't you add more risers?  You need 17.
Message 6 of 19
mcankusmez
Actually,I am drawing another plan and this plan have 10 stair for first floor.And third stair started in from 20 height.
for first floor.I share this plan you can see and it can be understand me.
Message 7 of 19
@mcankusmez wrote:
...and this plan have 10 stair for first floor.
are you saying 10 risers for the first floor?  That can't right.
Anyways, I can't open 2021 RVT, so I've got to pass on this one.
Good luck.
Message 8 of 19
mcankusmez
plann.pngIm sorry but ı didnt understand you.ı share main plan you can see because this plan have 10 stair for first floor
Message 9 of 19
mcankusmez
look at the picture.I do not understand, but there are 8 stairs on the 2nd floor
Message 10 of 19
constantin.stroescu
in the file that you attached in your post there's only one Level and the Landing is presented like a Floor Level...should I guess that you draw something but you think something else?
Constantin Stroescu
Message 11 of 19
mcankusmez
Actually I want to draw stair like picture but ı can't draw please help me merdiven çizimi.png
Message 12 of 19
constantin.stroescu
So you want to make a stair with two flights per Level  and you need an intermediate Landing.
It can easily done using Stair by Components , but it can be done , also (with more work) as Stair by Sketch , as you begin to do it.
Here is a screencast that continues your work...
https://knowledge.autodesk.com/community/screencast/f95fdc69-7d8e-4cb9-b35c-642af143ba3d
Constantin Stroescu
Message 13 of 19
mcankusmez
ı understand you but login door is 150x220 cm when we stair with 8 step doors and stair overlap ı dont understand what can ı do for it
Message 14 of 19
constantin.stroescu
that door is indeed a problem...
I propose you a change in order to can use that door:
Constantin Stroescu
Message 15 of 19
mcankusmez
unfortunately I cannot change the door, this plan has been drawn before and I am redrawing the size of the outer door is 150x220 cm, it is just a wrong furnishing but the actual door size is 150x220 cm
Message 16 of 19
constantin.stroescu
First . your door is bigger then  150x220
  • then, if you want to keep your design , you have to lower the entrance level as shown in my screen capture:
Constantin Stroescu
Message 17 of 19
and if you make higher risers ( close to 18 cm ) then you'll have to less lower the entrance level...
Constantin Stroescu
Message 18 of 19
mcankusmez
ı understand you but just ı put this door to see but normal door dimension is 150x220 nevertheless door lenght does not save the ladder stair landing going into it door ı share this ground floor plan you can see door dimension and other dimensionsbodrum kat plan 222.png
Message 19 of 19
mcankusmez
thank you your advice.I called my friend so project owner stair direction is wrong also ground floor is same floor its not in 20 height.And than stair step is 10 for ground floor and first floor thank you your advice thank you and ı am sorry
