I noticed that Revit likes to show the entire stair going down. This works for me in a lot of cases but I have a project that the second floor is showing the stair all the way down to the first floor, and there is another stair going from the second floor to the third that I really need to see.
Plan regions don't seem to allow me to add a break line below the second floor and see the stair from the second to the third floor.
I looked high and low for a solution and am stuck. The floors are on and the view is set to hidden.
The attached png shows the up stairs in blue that I would like to see and the Down stairs I would like to cut at the landing.
Thanks for all the help in advance.
Solved by chrisplyler. Go to Solution.
Ditto. It is shameful that something this basic was not integrally picked up in a release years ago.
This is a instance where technical "progress" is probably not genuine progress. There are so many patchwork mishaps in Revit that, taken together, inevitably frustrate an architect's ability to transcend the medium each day.
