Staircase railing transition
I have 2 conditions in a staircase that need to be addressed.
Issue 1: I have an individual straight railing on landing which needs to be connected to the next floor flight.
I need a smooth transition for the railing to turn.
issue 2: I want to resolve the same issue in 2 different flights of the railing. I know I could sketch a continuous stair run to have that joined but because of the complexity of the stair, I had to model them separately. I have attached 2 images of the condition and a supporting image of how I want that to look like.
Thanks.
 issue 1: at the red highlighted areaissue 1: at the red highlighted areaissue 1: 3d image of the same conditionissue 1: 3d image of the same conditionissue 2issue 2issue 2issue 2issue 2 desired transitionissue 2 desired transition
I can think of several approaches. Want to post the RVT file?
Thanks.
Like this?  If so, you can repeat what I did for the levels.
By the way, there are overlapping railings in your model.  Take care of them.
