Staircase Railing ( Curve)
Hi! Can anyone help me in how I can make the railing panel curve / follow the staircase profile? Attached picture for reference. Thank you so much!
Maybe useCapture.PNG a rail with the glass panel profile instead of the baluster panel.
Hi @ToanDN! Thank you for your reply, but may I know how can I do it when the intended design is perforated panel and not glass? Thank you!
You would need to model in place if you need curved and perforated panels.
Hi @ToanDN! Is there any other way to make it faster, for different dimensions and arc radius? Or I can only model-in-place each and every railing?
