I've created an ellipsoid form and I would like to cut the bottom off of it. I've created a simple cube shape as a void form but its not cutting the ellipsoid. It works when the void cuts partially through the ellipsoid but its hit and miss. Is there a way to fix this?
I tested and the void cannot fully cut the ellipsoid at the plane parallel to the plane (A) where I drew the semi-ellipse, but it can fully cut at planes not parallel to (A). So, it depends on where you draw the semi-ellipse in the first place.
Maybe this can be modeled without voids. Just modeling the portion of the ellipsoid that is necessary.
Something like this:
The only way is a little bit tricky so you have to draw the initial profile of the ellipsoid using the Start-end-radius-arc tool from the drawing bar so you can make a profile manually it will require you more calculation but it is the solution for your case
