stair strange behavior
Mohamed_Faramawy
Message 1 of 10
Mohamed_Faramawy
why do stairs do like this?
attached revit file
Replies (9)
Message 2 of 10
Sahay_R
Go into the sketch for the mirrored stair. Edit the boundaries at the weird part. remove the boundary segments for one of the risers and connect.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 10
Make the entire stair as one single sketch instead of 2 sketched runs + 2 odd landings + 1 normal run.  It also smooths out the bottom of the stair.
Message 4 of 10
Sahay_R
@ToanDN - What the OP did was create one stair and then mirror it. The new stair did not like to be mirrored.
Rina Sahay
Message 5 of 10
I understand.  If he fixed the original based on what I said above then he can mirror it without any problems.
Message 6 of 10
Mohamed_Faramawy
Kindly inform me if u tried this solution by yourself and it worked. And if
so can u attach the file with the fixed stair.
Message 7 of 10
Mohamed_Faramawy
i liked what u suggested very much, and i'll try to do it now, because i suffered from the stair bottom.
kindly attach the rvt file to learn ho to make the odd landing
Message 8 of 10
File is attached in my 1st reply.
Message 9 of 10
Mohamed_Faramawy
yes, sorry, i found it. but i have a question here.
i noted that u converted the stair to one sketch. is that right, is that what u are directing me to do in order to have clean bottom ?
Message 10 of 10
Yes.  Your stair is a winding stair.  There need not be any landings.
