Stair Riser/Tread Numbering
8 REPLIES 8
Message 1 of 9
studioconverge
2104 Views, 8 Replies
The riser/tread numbering tool is great, but how do you not show the numbers that are above the cut plane?
Thanks!
Labels (1)
8 REPLIES 8
Message 2 of 9
Masking Region.
Message 3 of 9
Thanks! I guess I should suggest to Autodesk that only risers below the cut line should be annotated since having floating numbers does not look smart.
Message 4 of 9
syman2000
in reply to: studioconverge
You can vote up this idea. Yes i agree Autodesk should give user ability to increase or decrease stair count value by stretching the line.
https://forums.autodesk.com/t5/revit-ideas/stair-numbering-show-only-to-visible-steps-in-floor-plans...
Message 5 of 9
...or:
Message 6 of 9
Is that arrow with the riser count an out of the box family or did you make that, or find it online?
Message 7 of 9
That's totally OOTB, @studioconverge ,  System Family: Automatic Up/Down Direction Family. Why?  What's unusual about it?  It's Type Parameters?
Message 8 of 9
I never seen the "16R" in front on the UP/DN arrow. I will take a look. Thanks again!
Message 9 of 9
studioconverge
in reply to: syman2000
How can I suggest this idea to Autodesk? Are they reading these forums or is there a particular place I should make this suggestion? Thanks!
