I was able to model this stair using runs and landings and it seems fine, however I am given the error message "Stair components are not continuously connected" and as you can see in the image, the stair railings do not properly wrap down the stairs. Even if I retry to make the railings, they do not wrap the second half of stairs. If I try to make the landings into separate runs instead, it still does not read as a continuously connected stair. A revit file with the stairs is attached. Thank you for your time and attention.
Solved by barthbradley. Go to Solution.
I can get there by creating and hosting Railing to a Hidden Reference Stair Type (red).
This is a great fast solution that manages at least to get the appearance of the railings to show correctly. Thank you very much!
