How to convert nwc to rvt
Message 1 of 13
Hi all,
I am a newbie & I'm not good at english.
I have a architectural drawing but this is nwc file.
How to convert nwc file to revit.
Thank all!
Replies (12)
Message 2 of 13
Alfredo_Medina
Hello, @Anonymous , welcome to the forum.
I don't think an .nwc file can be "converted" into Revit.  You can insert it into a Revit file as a coordination model and then save the .rvt file, but the coordination model will be just an external reference.
Message 3 of 13
Sahay_R
Hi @Anonymous - which version of Revit are you in? @Alfredo_Medina 's suggestion will only work if you are in Revit 2018.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 13
zhukoven
@Anonymous, if you're not in Revit 2018, there's no simple workflow:
1) You can export *.FBX from Navisworks > Open it with 3DsMax > Save as *.DWG or *.DXF > Open in Revit
2) You can try exporting Navisworks model to *.ifc format with one of the paid plugins (like this https://apps.autodesk.com/NAVIS/en/Detail/Index?id=5575831510149644553&appLang=en&os=Win64), then open it with Revit.
Both workflows are resource and time consuming, and may fail with large-scale models.
Message 5 of 13
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!Smiley Happy
No worries, we are here to help. The experts on this thread will be more than happy to guide you if you provide more information version etc.
See the article HERE on how to Link a file from Navisworks® and use it as a reference for a Revit model, providing context for the design.
Message 6 of 13
Thank you for help!
I linked .nwc into Revit & combine it with my drawing. But then, I export this file -> .nwd and open with navisworks, it does not view this coordination model ( that i linked into Revit ). ( I'm not good English so I hope you sympathize )
Message 7 of 13
Alfredo_Medina
In Navisworks, simply append the two files: 1) the .nwc of your Revit model, and 2) the .nwc that you already had.
Message 8 of 13
oh!
Thank you very much!
This is the first time i use navisworks.
Message 9 of 13
Viveka_CD
Thank you, @Alfredo_Medina
Hi @Anonymous
I'm glad to hear that you were able to link in the files.Smiley Happy
Please let us know if you have additional questions. We do have a Navisworks forum if you have specific questions.
Good luck with your project!
Message 10 of 13
habdellatif
Community Visitor
Community Visitor
how to make nwc to revit model
Message 11 of 13
Alfredo_Medina
Please clarify your question. Do you mean how to export from Revit to .nwc format?
Message 12 of 13
gustavo_almeidawlv29
Community Visitor
Community Visitor
I have a large .nwd file that I would like to convert to .3dbi.
From what I've studied, I would need to open it in Revit and use a plugin called "3DBi for Revit."
Then I would extract the file from Revit to the .3dbi format.
Do you know of any better methods?
Message 13 of 13
Community Visitor
Community Visitor
