Hi all,
I am a newbie & I'm not good at english.
I have a architectural drawing but this is nwc file.
How to convert nwc file to revit.
Thank all!
Solved by Alfredo_Medina. Go to Solution.
Solved by Viveka_CD. Go to Solution.
Hello, @Anonymous , welcome to the forum.
I don't think an .nwc file can be "converted" into Revit. You can insert it into a Revit file as a coordination model and then save the .rvt file, but the coordination model will be just an external reference.
Hi @Anonymous - which version of Revit are you in? @Alfredo_Medina 's suggestion will only work if you are in Revit 2018.
@Anonymous, if you're not in Revit 2018, there's no simple workflow:
1) You can export *.FBX from Navisworks > Open it with 3DsMax > Save as *.DWG or *.DXF > Open in Revit
2) You can try exporting Navisworks model to *.ifc format with one of the paid plugins (like this https://apps.autodesk.com/NAVIS/en/Detail/Index?id=5575831510149644553&appLang=en&os=Win64), then open it with Revit.
Both workflows are resource and time consuming, and may fail with large-scale models.
Hi @Anonymous
Welcome to the Autodesk community!
No worries, we are here to help. The experts on this thread will be more than happy to guide you if you provide more information version etc.
See the article HERE on how to Link a file from Navisworks® and use it as a reference for a Revit model, providing context for the design.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thank you for help!
I linked .nwc into Revit & combine it with my drawing. But then, I export this file -> .nwd and open with navisworks, it does not view this coordination model ( that i linked into Revit ). ( I'm not good English so I hope you sympathize )
In Navisworks, simply append the two files: 1) the .nwc of your Revit model, and 2) the .nwc that you already had.
Thank you, @Alfredo_Medina
Hi @Anonymous
I'm glad to hear that you were able to link in the files.
Please let us know if you have additional questions. We do have a Navisworks forum if you have specific questions.
Good luck with your project!
Viveka CD
Please clarify your question. Do you mean how to export from Revit to .nwc format?
I have a large .nwd file that I would like to convert to .3dbi.
From what I've studied, I would need to open it in Revit and use a plugin called "3DBi for Revit."
Then I would extract the file from Revit to the .3dbi format.
Do you know of any better methods?
