Stair Path Arrow - up to the top?
adamskaEXHPY
adamskaEXHPY
Hi guys,
I am struggling with finding the setting to extend the stair path arrow until the top of the stairs...
Any idea where I can find it? Thank you 🙂
Create a plan region with the cut plane above the top of the stair and the view range bottom at the base of the stair.
adamskaEXHPY
Hey, thanks for the suggestion but it didn't extend the arrow.
RDAOU
@adamskaEXHPY
See Below GIF...
  • Case 1: Single Level 1 to Level 2
  • Case 2: Continuous All Levels
See which suits your case best...otherwise, attach the file to set it up as per your model
You can get there with a Plan Region, but it takes some fidgeting with View Range. There's a sweet spot that exits that will show the whole arrow/path uncut and continuous from top to bottom.
Then the view range of your plan region is not setup properly.
mikael_saaw
The setting you are looking for it's under Visibility/Graphics override, Annotation Categories and Stair path.
You need to check <Above> UP Arrows.
Hope it helps!
