Stair Numbers missing (when printing)
info
info
HI,
I'm missing stair numbers when printing,
When zooming in & out in Revit the stair numbers  disappear and reappear sporadically?
See attached.
PrathapSekar
Have you tried the following link?
 https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Views-ha...
Guess this may help you, if you did not try the above link already!
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
info
Hi Thanks for the link;
The zooming in/out and missing stair numbers is a problem. But I know the tread numbering is in the model.
But It's more that the numbers are not printing
- to fix this I had to number each missing step (with text) individually which was quite tedious, and annoying due to knowing the stairs were already numbered.
info
thanks again I reviewed the link;
If I close the file, switch off Accelerated Hardware - open file & print, the stair numbers appear in the print!
I don't fully understand how the the Accelerated Hardware is involved with producing a PDF, but it appears to work.
But like I said; it only works after closing file, changing settings, and reopening again to take effect.
PrathapSekar
Glad you found this helpful!
