As i was trying to create a topography element in Revit , as soon as i finish putting the point on the site and I accept , the points are not appearing anymore, can someone help me with this ?
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Constantin Stroescu
How you can see points while in Project , out of Edit Mode by using Dynamo:
Constantin Stroescu
Sounds like the Point Elevation you entered is outside of the View Range. Set Top, Bottom and Depth to Unlimited. See them now?
