Stair end riser cannot connect properly with floor slab
shihas.pms24
shihas.pms24
Hi Experts,
I have created a stair from GF to First floor level (Ex-10 riser). So, in floor plan layout 10 riser, but in section the last riser and First Floor slab not connect properly (1 riser gap is there). So to fix it i create a landing at end of the 10th riser, then it solved in section. But in floor plan layout there is 1 extra riser. means, the required number of riser is 10 but including the landing its looks 11 riser. i tried to hide that landing in floor plan layout but its not working. So any solution to sole it.......................
Thanks in Advance...
Edit stair,  select the run and check End wiith riser.
shihas.pms24
It already i tried but its show just a riser only still not connect properly . It should be connect like the attached image. but in the image actually its a generic model.
If you want that you still need to uncheck End with riser and stretch the run add one more step to the top, or add a landing at the top of the stairs.
Are you saying that this thing highlighted in screenshot below is the Generic Model?
If so, why don't you just move the stairs closer to the floor?  😉
shihas.pms24
this method also i did. its solved in section view but in plan 1 extra riser visible. means ,if the required number of riser is 10 , when adopt this method the total number of riser in pan is 11. the last riser (The landing cannot hide also in plan).
shihas.pms24
This is now as per your suggestion. But when we draw a stair section, by default section will be like this.  see its properly not connect with floor slab.
Either should connect with slab nor will connect it with a beam as per my first screenshot. Still you can see the bottom of slab and stair run not merge together.
