Stair Display
Stair Display
craig
Message 1 of 8
Stair Display
craig
We are relatively new to Revit coming from Autocad Architecture and struggling to work with stairs. Modeling them is fine but displaying them correctly is a challenge.
* down runs of stairs do not respect the view depth range
* Down runs just show all has full lines -no break line or dashed risers below a cut plane
* Up runs do not respect view upper range
Am I missing something or do the stairs only half work  when trying to represent in plan.
Autocad couldn't get it right either.... I was really hoping somebody had taught the Revit team what the industry needs. Any points or tutorials would be appreciated
Replies (7)
Message 2 of 8
dzanta
If you can send some pictures and redlines of what you want the stairs to look like in floor plan, I can help.  Thanks.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 8
Down runs always display complete regardless of View range
See above
Up runs do respect view range's cut plane.  Please show an example if it is not the case.
Message 4 of 8
corkybenle
you can create a plan region to encompass the stairs to modify the Cut Plane and how the single/double lines look if that helps you any.
Message 5 of 8
@craig :
Read the information found at this Link and note the 4'-0" rule and what Categories are effected by it and how.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Message 6 of 8
craig
Thanks - This is an example of what we produced in Autocad - Yes drawn lines but this should be able to be generated in Revit surly ???
Message 7 of 8
craig
this seems like alot of work - I was hoping for a simpler solution
Message 8 of 8
craig
Thanks for the link - I haven't yet really tested all the things in it but it was interesting about the 4 foot thing ???
