I need the area tags to be under the column and not graphicallu divide it.
Any help?
Sorry,
yes those are areas. Area tags are hidden.
I want those areas be under the columns - graphically.
thanks
I have it set as in background there in a teplate. but it is not under the wall or column 'hatch'.
Do all the walls overlap the color? Change to Hidden Line Visual Style to verify. If so, then "Background" is set and working as it should. Is this not what you were looking for?
