Good morning,
Stairs are governed by different codes effectively. But above all your question is too vague. Indeed stairs have regulations according to their destination.
If you use stairs in environments open to the public I invite you to use this page of the French government site.
http://www.accessibilite-batiment.fr/erp-neufs/circulation-interieures-verticales/escalier/arrete.ht...
For stairs in housing are less restrictive, but it respects a law known as "Blondel" which consists in calculating the rise of a staircase as follows a bosom multiplied by two heights should be equal to sixty four. this makes it possible to obtain comfortable stairs.
Another site on the subject of stairs: https://fr.wikipedia.org/wiki/Escalier
Then according to the establishments it is necessary to calculate the units of passage according to the affluence of the place and its destination.
One last thing, the steps must be defined according to the number of steps per flight, a flight can not exceed a number of steps greater than twenty.
Attention to finish to check well the destination of your building, according to its use the rules will change and will be more or less constraining for the vertical circulations and the elements of protections, like the ramps of access for the persons with reduced mobility and the railings.
Reference for environments governed by the labour code :
https://www.legifrance.gouv.fr/affichCode.do?cidTexte=LEGITEXT000006072050
Reference for environments governed by the building code :
https://www.legifrance.gouv.fr/affichCode.do?cidTexte=LEGITEXT000006074096
Reference for establishments receiving the public :
https://www.service-public.fr/professionnels-entreprises/vosdroits/F32351
Obviously not everything is in these texts, but it is a beginning.
Have a nice day.
Translated with www.DeepL.com/Translator
Bonjour,
Les escaliers sont régis par différents code effectivement. Mais surtout votre question est trop vague. En effet les escalier ont des réglementations selon leur destination.
Si vous utilisez des escalier dans des environnements recevant du public je vous invite à utiliser cette page du site du gouvernement français.
Pour les escalier en habitation sont moins contraignant, mais il respecte une loi dite de "Blondel" qui consiste a calculer la montée d'un escalier comme suit un giron multiplier par deux hauteurs devrait être égal à soixante quatre. ceci permet d'obtenir des escalier confortable.
Un autre site sur le sujet des escalier : https://fr.wikipedia.org/wiki/Escalier
Ensuite selon les établissements il faut calculer les unités de passage en fonction de l'affluence du lieu et de sa destination.
Une dernière chose, les paliers doivent être définit selon le nombre de marche par volée, une volée ne peut pas dépasser un nombre de marche supérieur à vingt.
Attention pour finir à bien vérifier la destination de votre bâtiment, selon son usage les règles changeront et seront plus ou moins contraignantes pour les circulations verticales et les éléments de protections, comme les rampes d'accès pour les personnes à mobilité réduite et les gardes-corps.
Référence pour les environnements régis par le code du travail :
Référence pour les environnements régis par le code de la construction :
Référence pour les établissement recevant du public :
Evidemment tout n'est pas dans ces textes, mais c'est un début.
bonne journée.
Jacques Rigal
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
