Stacked Wall minimum height
I've made wall with one part variable height, other part 20mm high.
Revit won't make the wall, error message says "Can't make wall."
Why?
ennujozlagam
@Anonymous hello, you ca try this, pick the wall > go to properties > edit type > edit> and check the sample height it could be value is lower. change the height. hope it helps. thanks
BIM.Consultant
The minimum height of basic wall should be 31 mm otherwise revit will give error "Cant make wall". To overcome this, create a wall type and add reveal that is 20mm from bottom. In the stacked wall make the height to be at least 31mm for this wall.
BIM Consultant
Yugal_Gupta
Minimum Wall height which Revit can model is 30.48mm or 0' 1 51/256".
