Spot Light Light Source Property Issue - Revit 2016
Message 1 of 1
I am having trouble adjusting the angle properties (Spot Beam Angle, Spot Field Angle, Tilt Angle) of the "Ceiling-based spotlights" onto the building model.
The online manual indicates that I should:
Select light --> Type Properties --> Scroll to "Photometric" --> Alter angles to desired values.
(See attached picture)
However, the new properties did not change the light source of both the preview displayed and the light placed in the model.
Note: When I alter the "Light Source Symbol Length" under "Dimensions", the preview and the placed component does correctly alter to the desired value.
Does anyone else have this problem too? Thank you!
Replies (0)
