Message 1 of 12
12:37 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Deep into documentation, I was directed to raise our building 500mm. To avoid having to edit the elevation scope box for the 1300 room elevations that were already made, I used "relocate project" to raise the overall model 500mm, then dropped the topo-surface 500mm.
What I found after I did this was that the numerous point levels that generate the toposurface differ by 500mm from the spot elevations.
Is there anyway to change this so the topo-surface point levels match the spot elevations as its doing my head in.
Thanks in advance
