Spot Elevation
Spot Elevation
Spot Elevation
I want to know if's possible to creat a spot elevation with a text label ? I want to be able to change the text above the leader. I want to creat a spot elevation like the attachement.
Karol_Piroska
I'd say the easiest way is to create new type and add "elevation Indicator" text there. This way you cna just easy change one type to other .. like top of wall, concrete, foundation etc etc
aleksei.tkachenko
Hello
You need to assign symbol in spot elevation's type properties. Before that you have to create Spot Elevation Symbols Family. Use "Metric Spot Elevation Symbol" template.
I want to creat a label in the family of spot elevation symbol which i can change later in a project
isnt there already one there - in so far as you can add a prefix or a suffix to the level - like TOC / TOS / etc etc
