Hi Sir,
Cant able to access the files inside the revit server folder
thanks
Regards
Manu
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community! ![]()
If you encounter an issue with Revit Server, start the troubleshooting process here
Let us know if this helped resolve your issue.
Please mark this response as Accept as Solution if it answers your question. Kudos gladly accepted.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @Anonymous,
You cannot access a Revit Server file like you can a file on a regular server.
If you want to copy, delete, lock or modify a Revit Server file, you have to go through the Revit Server Administrator.
You can also grab a file just by detaching from central and save locally.
