Hello, how can I lower the "EG"and also how can I change the number manually?
Solved by sabamail65. Go to Solution.
Solved by RDAOU. Go to Solution.
@sabamail65 wrote:
Hello, how can I lower the "EG"....
Howard Munsell
Meinst du Erdgeschoss just Level? or the Entire project? If only the level...open a section or elevation view select the level and Either change it in the Level Head if it shows the level OR on the properties palette
If you want to change the Elevation of the whole project then you need to work with the Project Base point
