Spot elevation
3 REPLIES 3
sabamail65
533 Views, 3 Replies
Spot elevation
Hello, how can I lower the   "EG"and also how can I change the number manually?
3 REPLIES 3
hmunsell
in reply to: sabamail65
@sabamail65 wrote:
Hello, how can I lower the "EG"....
  • What is the "EG" ?
  • the Spot Elevation only reports the elevation. you can not change it thru the tag. you have to change the element it is reporting on.
Howard Munsell
RDAOU
@sabamail65
Meinst du Erdgeschoss just Level? or the Entire project? If only the level...open a section or elevation view select the level and Either change it in the Level Head if it shows the level OR on the properties palette
If you want to change the Elevation of the whole project then you need to work with the Project Base point
sabamail65
in reply to: RDAOU
thank you dear RDAOU
