SPOT ELEVATION SYMBOL - SURPRESS NUMBERS
1 REPLY 1
1287 Views, 1 Reply
I cant find a way of supressing the height figured numbers (to replace with GFL and 1FL) . Prefix and suffix do the text ok but for appearance sake (ie client requirement) want to change lots ov spot heights to surpress the numbers. How can I do this - I realise its a system family but usually there are some params - not on this family though?
1 REPLY 1
AJA14
I don't quite understand what you're trying to accomplish but anyways, if you select the level and edit type, you will see the level name and if you access that it will take you to the family where you can see the level head family. Once you know the level head family, locate it in the project browser, right click, edit family and change to your preferences.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Forma Design Contest
Technology Administrators
