05:54 AM
I'm designing a piping system and I'm putting spot elevations annotations at the connections. I'm using "current level" as relative base to show the distance from the floor to the top and bottom parts of the pipes. For some reason it gives me a number that is 55 mm less than the actual height. I tried with my colleagues computer on a completely different project and he has the exact same problem, also 55 mm difference. How could this be? I assume it is something general as we both had the exact same difference in height. We use Revit 2017.
Thanks!
