Spot elevation and Roof Problem
mcankusmez
Message 1 of 14
mcankusmez
Hi.Firstly, ı cannot add my elevation head How can ı add and seen my spot elevation head ? .Secondly, I did a roof but when ı look roof on roof plan,it looks like the picture is it true ?
Replies (13)
Message 2 of 14
Just place new Spot elevations for the new floors.
You don't actually say what the problem with your roof is.  We don't know what its supposed to look like.  Perhaps the view is set to Wireframe, if that is what you are referring to.
Message 3 of 14
Message 4 of 14
mcankusmez
my roof lookslike picture with 3d
Message 5 of 14
mcankusmez
ı cannot see your solution
Message 6 of 14
It looks as if your view range isn't high enough to see the plan.  Set it to be higher.
Message 7 of 14
mcankusmez
How can ı do it.Shall you do it and record video for me when ı upload my project ?
Message 8 of 14
Do you understand that Annotations (e.g. Spot Elevations, Tags, Text) are VIEW-SPECIFIC ELEMENTS?
View-specific elements display only in the views in which they are placed.
Message 9 of 14
mcankusmez
I didnt understand just when ı upload my elevation head ı want to see with edit type like the picture.You can see my evelation (Turkish evelation head) is not seen this panel
Message 10 of 14
mcankusmez
Do I need to upgrade the value in the view range ? If your answer is yes.How can ı change ?
Message 11 of 14
It's not clear what you're asking.  Your roof doesn't display properly because the view range is not high enough to see the whole roof.  Barthbradley shows in his post how to adjust the View range so that you can see the whole roof.  Look for View Range in the View properties.
Are you asking about copying your spot elevations - as mentioned, these are view specific.  Create new ones to show on different elements.
Or are you asking about the Spot Elevation head?  If so what are you asking?  Note that the Elevation Head has nothing to do with the View Range.
Message 12 of 14
ennujozlagam
please see screencast. thanks
https://autode.sk/2Wg5LOt
Message 13 of 14
mcankusmez
thank you thank you so much. I solved the problem with the issues but ı have a question how can ı draw flue or flues gap ?
Message 14 of 14
ennujozlagam
you can try to use model in-place extrusion or sweep. thanks
