Split Faces using api
ratno123s
ratno123s
How to split a face of a wall in to two (given the curve or points defining the boundary or area) using api.
aim is to achieve functionality similar to Split Face tool in revit through api
RDAOU
Hi @ratno123s
The Revit API forum can be found on the following link https://forums.autodesk.com/t5/revit-api-forum/bd-p/160
PS: Kindly do not cross post the same question on various boards of this forum...please follow up on the same question posted on Revit API https://forums.autodesk.com/t5/revit-api-forum/split-face-using-api/td-p/6624321
