Nachricht 1 von 5
mishkt
294 Aufrufe, 4 Antworten
STAIRS
I tried to create stairs, but I do not why, I have different heights of risers and one riser just didn't create.
I attached some screenshots of plan, section and 3d view.
Level height - 3240 mm
18 risers
Riser height - 180 mm
Thank you for your help
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: mishkt
Hello, pick your stair edit then go to properties uncheck end. Thanks
Nachricht 3 von 5
mishkt
als Antwort auf: ennujozlagam
Thank you for answer.
Uncheck in type properties?
If yes, it doesn't work
Nachricht 4 von 5
ennujozlagam
Hello, check my stair screencast video and see if can help you. Thanks
Nachricht 5 von 5
@mishkt If doing what @ennujozlagam suggested doesn't work, you may want to edit the stairs and recreate the problematic run.  Feel free to post the Revit file if you want us to look at.
