split face
split face
76jsa
Message 1 of 11
split face
76jsa
I need to split face horizontally and vertically in the same time, to have tiles.
Split face allows me only one direction / not intersecting.
Any help?
Replies (10)
Message 2 of 11
hmunsell
Why...? what is it your are wanting to accomplish?
Howard Munsell
Message 3 of 11
constantin.stroescu
is it not better to make it as a custom Curtain Wall?
Constantin Stroescu
Message 4 of 11
You can add tile lines and a map to the surface layer of the wall.  This will save the time of splitting the face and applying paint to each tile.
Message 5 of 11
76jsa
Tiles to the surface does not work, because the divisions are not supposed to be all same.
Curtain wall doesnt work too - i have a structure wall with 4 layers. A i want to split face of the exterior one.
The goal is to divide the face of the facade to various tiles.
Message 6 of 11
Do you have an image or sketch of what you're trying to achieve?
Message 7 of 11
76jsa
rectangular tiles.
Message 8 of 11
Are they regular?
Do they have a pattern?
Message 9 of 11
76jsa
Message 10 of 11
I'm not sure why a tiled finish won't work from your image.
However, you can split the face of a wall into tiles.  You just need to create them individually.  This seems like a lot of work, so we need to investigate if there are easier solutions.Split face.JPG
Message 11 of 11
loboarch
Split face tool allows you to sketch a shape on the face. it follows the same rules as sketching in Revit. YOu can darw the sketch in any direction.
http://help.autodesk.com/view/RVT/2021/ENU/?guid=GUID-C968BF26-C425-4DAE-A93E-CEDA2C1224B7
This example in the video shows sketching squares (edges are horizontal and vertical) on a wall.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
