Hi !
I can't find any easy drawing solution , hard to decide which is good and not overcomplicated
have some background with autocad but some things are overcomplicated in it , tables and style overrides , hatches and many more.
Maybe that answers will help me a bit to understand what revit can do or do easily unlike other solutions.
1) Doors , Can I display 2 states of doors on plan ? , like on that image
2) Can I make layered walls , 1 inside layer will be 400mm width , outside 100mm in width , but outside will be 200mm taller , in same time windows and openings , doors and curtainwalls should cut both layers like one body , in other words custom layered wall (with different layer height) which is treated like one body. is that possible in revit ?
3) Is revit good for landscape design ? Does it have good enough tools to draw ground isolines and good library to scatter vegetation (top view assets and also elevation assets) those are good examples :
Thanks !
