Hello dear Revit users,
I am trying to assign different colors on a floor ( a lot of deco seals / joints )
Using split face and paint tool was ok untill I had to work on the slope angle : (
If I move the points of the floor, the splited faces must disappear. I tried to give the angle to the floor before spliting but Revit does not allow to split face on it.
Any solution ?
I hope that my question is clear
Thank you !
A method to do it could be the following one:
Constantin Stroescu
Roofs themselves allow split Face but it seems that I am not able to place material on split faces...
Constantin Stroescu
Thank you Constantin,
I could also make thin slabs , and I have all the outlining to create extra shapes.
My worry is about making the model heavy, knowing that it is a part of a bigger project. Iam trying right now to use "create parts" . Would it be a solution ?
What do these splitted faces of yours look like, just to get some idea of that... I wouldnt use split parts on the entire floor, maybe on a top layer then...
