Spline moves upon dissolve form command
stephenc9VRE3
stephenc9VRE3
Splines are being displaced from original modeled position when I dissolve the form. Why?
@barthbradley any insight?
Dissolve? So you're reducing the form to its underlying editable curves?  Why?
stephenc9VRE3
Dissolving the form to underlying Spline to modify the form. Fortunately I keep a copy of the raw underlying Spline work prior to creating forms, but it seems like a glitch for the original lines to skip around like this when dissolving the form.
Also, if I try to modify/edit the Spline within the actual form itself, it reduces all driving control points to a normalized reference plane. Obviously this does not give me the same flexibility to modify the form as the 3D driving points on a Spline
Why not X-Ray?
stephenc9VRE3
Why not X-ray! Didn’t know that was an option. Perfect thanks so much for your attention to this.
Much appreciated.
