Specific Levels in View Range
Message 1 of 10
Hi all,
I have a view and I want to control a view depth, but the levels that I need, don't appear in the drop down box.
Can someone explain the mechanism of how Revit decides which level appears in the primary range: Top, Cut Plane and Bottom.
Thanks a lot!
Replies (9)
Message 2 of 10
aRcHiTeCt.JM
... can you post at least a screen shot to see the issue
.... please
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 10
are you referring to this?
or this?
Message 4 of 10
GHASEM_ARIYANI
Hello @Anonymous
view-range-revit
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Message 5 of 10
aRcHiTeCt.JM
.... view range
The view range is a set of horizontal planes that control the visibility and display of objects in a plan view.
Every plan view has a property called view range, also known as a visible range. The horizontal planes that define the view range are Top, Cut Plane, and Bottom. The top and bottom clip planes represent the topmost and bottommost portion of the view range. The cut plane is a plane that determines the height at which certain elements in the view are shown as cut. These 3 planes define the primary range of the view range.
View depth is an additional plane beyond the primary range. Change the view depth to show elements below the bottom clip plane. By default, the view depth coincides with the bottom clip plane.
The following elevation shows the view range  of a plan view: Top , Cut plane , Bottom , Offset (from bottom) , Primary Range , and View Depth .
The plan view on the right shows the result for this view range.
Display of Elements in the Plan View
  • Elements outside the view range do not display in the view unless you specify an underlay to show a level outside the view range. For information about the Underlay view property, see View Properties.
  • Elements display in the plan view using the cut line weight, the projection line weight, or the <Beyond> line style, according to the rules described in the sections below.
    • To change the display of line weights for cut elements and projection elements, use the Object Styles tool.
    • To change the display of the <Beyond> line style, use the Line Styles tool.
  • Display of elements in reflected ceiling plan (RCP) views is similar to their display in plan views, with the exception that elements are presented as viewed from below and mirrored.
Elements Intersected by the Cut Plane
In a plan view, Revit uses the following rules to display elements that are intersected by the cut plane:
  • These elements are drawn using the cut line weight of the element category.
  • When the element category does not have a cut line weight, the category is not cuttable. The element is drawn using the projection line weight.
Exceptions for the display of elements intersected by the cut plane include the following:
  • Walls shorter than 6 feet (or 2 meters) are not cut, even if they intersect the cut plane.
    The 6 feet (or 2 meters) are measured from the top of the bounding box to the bottom of the primary view range. For example, if you create a wall whose top is 6 feet above the bottom clip plane, the wall is cut at the cut plane. When the top of the wall is less than 6 feet, the entire wall shows as projection even where it intersects the cut plane. This behavior always occurs when the Top Constraint property for the wall is specified as Unconnected. If the top constraint property of the wall is specified as Connected, then the cut plane position is always used to define if the wall is cut or projected.
  • For some categories, individual families are defined as cuttable or non-cuttable. If a family is defined as non-cuttable and its elements intersect the cut plane, they are drawn using the projection line weight. See About Non-Cuttable Families.
In the following elevation, blue highlighting indicates elements that intersect the cut plane.
The plan view on the right shows the following:
 Elements that are drawn using the cut line weight. (walls, door, and window)
 Elements that are drawn using the projection line weight because they are non-cuttable (casework).
Elements Below the Cut Plane and Above the Bottom Clip Plane
In a plan view, Revit draws these elements using the projection line weight of the element category.
In the following elevation, blue highlighting indicates elements that are below the cut plane and above the bottom clip plane.
 Elements that are drawn using the projection line weight because they are not intersected by the cut plane. (cabinet, desk, and chair)
Elements Below the Bottom Clip Plane and Within the View Depth
Elements within the view depth are drawn using the <Beyond> line style regardless of the element's category.
Exceptions: Floors, structural floors, stairs, and ramps located outside the view range use an adjusted range that is 4 feet (about 1.22 meters) below the bottom of the primary range. Within this adjusted range, the elements are drawn using the projection line weight for the category. If they exist outside this adjusted range but within the view depth, these elements are drawn using the <Beyond> line style.
For example, in the following elevation, blue highlighting indicates elements that occur below the bottom clip plane and within the view depth.
 An element (foundation) within the view depth that is drawn using the <Beyond> line style.
 An element that is drawn using the projection line weight for its category, because it meets the exception conditions.
Elements Above the Cut Plane and Below the Top Clip Plane
These elements are not displayed in a plan view unless their categories are window, casework, or generic model. Elements in these 3 categories are drawn using the projection line weight as viewed from above.
For example, in the following elevation, blue highlighting indicates elements that occur between the top of the view range and the cut plane.
 Wall-mounted casework that is drawn using the projected line weight. In this case, the dashed line style for projection lines is defined in the casework family.
 The wall sconce (a lighting category) that is not drawn in the plan because its category is not window, casework, or generic model.
View Range in a Reflected Ceiling Plan (RCP)
Like plan views, reflected ceiling plans also have a view range setting but with some differences.
  • A reflected ceiling plan's view direction is up from the cut plane.
  • A reflected ceiling plan includes the cut plane as part of the primary range, but it is typically positioned above the cut plane of a plan view. Cut planes in a reflected ceiling plan are often set above the head height of the doors and windows.
  • The area between the cut plane and the top of the view range establishes the primary view range of the view. The bottom setting of the view range is not used in a reflected ceiling plan. Elements falling in the primary view range will use the projection line weight.
  • View depth is established in the up direction from the cut plane. Elements not in the primary view range but within the view depth will use the <Beyond> line style.
Note: Plan regions are used to control the appearance of hosts and hosted elements, primarily windows and doors in walls, when their elevation affects whether they are visible. Plan regions cannot be used to control the display of MEP elements.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 6 of 10
Stand by...180 minute Screencast will upload shortly.  Full HD Video and Sound.  Narrated by Morgan Freeman. Cameo appearances by Brad Pitt, George Clooney,  Matt Damon, Mark Wahlberg and more!
Message 7 of 10
aRcHiTeCt.JM
.... I thought we were "playing" .... who will show more...
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 8 of 10
Discussion_Admin
@barthbradley @aRcHiTeCt.JM
Alright you two.
I am getting reports on the attempts at humor.
DA
Message 9 of 10
@Anonymous,
Another thing that determines what levels show up in your view range editor has to do with what level the elements are associated. For e.g.: You will see Level 2 and not Level 1 if your cut is cutting in the area where level 2 elements were assigned.  If you need another level to show in the editor you need to set and underlay or overlay option to include those levels in the editor to modify.
Message 10 of 10
andrei.boboc
I have a similar understanding, about "view range", for structural plans, when I must look up, no down, and I must reflect the walls from both levels with different hatches. In your pictures, I'm similar with "Ceiling View Range", but I don't understand where is starting the "view depth".
Thanks.
