- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I created a semi-recessed toilet paper holder family (attached - it's a nested family, using a manufacturer's face-based family loaded into a wall-hosted family with a void to cut the wall at the recess). In the family, I created a reference plane parallel to the reference level, put a dimension on the reference plane called mounting height, and locked the nested family's center to the reference plane. In the family, if I adjust the Mounting Height parameter, it works as expected. Load it into the project, though, and it doesn't respond to that dimension at all - the only value that will control its height is an instance parameter called "Elevation from Level" that does not exist (or at least is not visible/editable) in the family. This is a problem, as the "Elevation from Level" parameter measures to the lowest point in the family, and this should be measured to the centerline. It's also a problem because I want all my dispensers at the same height, by default, rather than having to set each one--an instance parameter overriding my type parameter dimension messes that up. I know there are workarounds for this, but I'm looking to find a solution to the fundamental problem--why this Mounting Height parameter does not affect the height in the model when it works in the family. Is this something unique to specialty equipment families? Is there a way to get it to work as expected, or is there no way to overrule the "Elevation from Level" parameter that doesn't serve well here? Or am I missing something else entirely?
