Sloped & Tapered Wall
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
119348566
768 Aufrufe, 10 Antworten
How would I model a Tapered wall that stays flat at the top but the base varies from 4.5m to 6m deep? Any help is appreciated
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: 119348566
Do you mean the base has different thicknesses or different elevations?
Nachricht 3 von 11
119348566
als Antwort auf: ToanDN
Different elevations
Nachricht 4 von 11
Then model a normal tapered wall and attach it's base to the sloped slab. If you don't have a sloped slab, edit the wall profile, or draw a sloped ref plane and attach the wall base to it.
Nachricht 5 von 11
119348566
Is there any chance you could show me some step by step? Im not familiar with how to attach to the bottom
Nachricht 6 von 11
Select the wall, click Attach Top/Base button on the Ribbon, choose Attach Base, select the sloped slab at base
Nachricht 7 von 11
119348566
By creating a sloped ref plane and adding the base of the wall to it would it stretch the wall downwards until it came into contact with that slope of the plane?
Nachricht 8 von 11
No. You don't have to stretch anything.  Use Attach Top/Base to attach the wall base to the plane.
And I just looked at your picture, you clearly have a sloped slab then just attach the wall base to the slab.
Nachricht 9 von 11
119348566
Alright that makes sense, Thanks a lot!
Nachricht 10 von 11
119348566
Ive come across an addition to this problem, how would i attach the base of the wall to extend below the slab rather than stop at the top of the slab?
Nachricht 11 von 11
Go to an elevation, draw a ref plane at the bottom of the slab, attach the wall base to it.
