Spandrel panel in window help
shaun_darganGVEJ7
Observer Observer
shaun_darganGVEJ7
Observer
Observer
I have a window which has a opener above a spandrel panel.
Internally we have a sill that is centered to the transom.
I have built the window family however when inserting the cut is the full height.
is it possible to have the layers of structure at different heights.
Any help would be great.
Got screenshots?  I can't visualize what you are describing.  Maybe posting the RVT would be best.
shaun_darganGVEJ7
Observer
Observer
Cheers for the reply, I should added this to start with.
hopefully the sketch and help.
Is this all you are trying to do? Something like this?
shaun_darganGVEJ7
Observer
Observer
yes that is spot on, however will that work as windows.
we are developing a digital twin of current buildings and these are tilt turn windows with panel below?#
are you able to share the solution.
It's nothing special. Just an Embedded Curtain Wall with a pony wall and floor (sill) behind it.
shaun_darganGVEJ7
Observer
Observer
Brilliant i will give this a go. appreciate your help on this.
