Space separator acts as a room separator.
rlo6LRKS
Message 1 of 16
rlo6LRKS
Hi everyone. Maybe someone has an idea on how to fix this issue.
Working on a central file that is saved on our server.
We have rooms in the project that we have split in spaces with space separator.
After synchronizing the space separator acts as room boundaries.
We are not sure what might cause this issue.
Replies (15)
Message 2 of 16
RDAOU
@rlo6LRKS
Works as expected here...are you sure you are not confusing Room with Space separators'?
Message 3 of 16
rlo6LRKS
First screenshot with a selected room tag and the red line around the are that it reads as a room.
Second screenshot with a selected space separator.
I am sure.
Message 4 of 16
RDAOU
@rlo6LRKS
I am unable to tell much from those images
  • Which Version or Revit are you using? Updated?
  • Did you check for multiple bounding elements?
  • Go to Visibility graphics and enable Rooms Interior Fill and Reference then post an image of that please
Or even better...apply a color scheme By Room Name to show a clearer picture of room extents
Message 5 of 16
rlo6LRKS
Also did not mention, it is Revit 2020, if that changes anything.
Message 6 of 16
RDAOU
@rlo6LRKS
Nope...I haven't been using 2020 for a while but I've just double checked and rooms are not bound by Space separators
Message 7 of 16
rlo6LRKS
The only room bounding elements that I use is the ARK linked file.
This is how it looks like after enabling Interior fill and Reference in visibility and graphics
There is Architects room in grey, ours with black.
Message 8 of 16
rlo6LRKS
It should not be room bound, but for some odd reason it happens in all the rooms after sync.
Message 9 of 16
RDAOU
@rlo6LRKS
Then open the architectural link and check the bounding elements therein...I bet you will find a room separator there
Message 10 of 16
rlo6LRKS
But there is no way that the Architect placed Room separators in all those places exactly as our Space separators.
Message 11 of 16
RDAOU
@rlo6LRKS
Only you have access to the model and the linked models. I cannot tell from my end what is in there.
  1. check the link for bounding elements,
  2. check the associated level of those views,
  3. make sure the rooms are placed on the right level
  4. check the computational height of the level
  5. and check whether the rooms are being bound by elements hosted on a different level
  6. ....
Message 12 of 16
rlo6LRKS
It is the space separator because when deleting it the room goes back to the proper area.
And the space separations initially worked well. It is only when my colleague is using the project and syncs, that the rooms get bound by the Space separators. So the issue/bug is coming from elsewhere.
Message 13 of 16
If you delete a space separator, is the room changed?
Can you tag linked rooms instead of recreate them?
Message 14 of 16
This has been posted about in at least three other threads that I personally participated in.  It could very well be a bug - or, at minimum, a fluke.  You might want to open a Support Case on this.  If you do, please let us know outcome.
Following...
Message 15 of 16
rlo6LRKS
Yes, if I delete it the room is bound by walls again.
Then I can place a space separator again without any problems.
Message 16 of 16
rlo6LRKS
Will do that this week if things continue to ´lag´
