I select an object and opened properties. I want to add some parameter under "Text". Could anyone help me with that?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Do you me that you want to add a custom Text-type Project Parameter to Ceiling Properties, and have it displayed under the "Text" Group?
...Create a Project Parameter, make it a Text-type Parameter, Group it under "Text" and assign it to the Ceiling Category.
Should these information be per Type, not Instance? Edit a ceiling type and see if it already has similar parameters that you can use such as Manufacturer, Model, etc... If you create a schedule you can use those parameters and simply rename the header name to whatever you want if you insist on adding them as custom text parameters, set them to Type instead of Instance
Hello @chen0792
you can use Manage tab > Setting panel > Project Parameter/Shared Parameter.
Project Parameter = can appear in schedules but not tags.
Shared Parameter = can be shared by multiple projects and family and tag and etc...
