Some schedule types dont have break, others dont have merge cells, help!
Message 1 of 8
I am using Revit Schedules to create general notes and charts, etc. as you do.
Problem is the ones I created, which have all the formatting tools (insert row, merge/unmerge etc) doesn't have schedule break handle on the sheets.
The other one, which I created from scratch following a tutorial, has a break, but doesn't have insert row (only insert data row) and doesn't have merge unmerge.
see attached the different ways they behave
Any help?
Replies (7)
Message 2 of 8
one last image
Message 3 of 8
I seem to be jumping through some hoops here opening your png files.  Can you just post via "Photos" button?
Message 4 of 8
formatted schedule, no break.PNGunformatted schedule, yes break.PNGformatted schedule, fromatting options.PNGunformatted schedule, formatting options.PNGsorry my bad
Message 5 of 8
The one with full text they type everything in the Title/Header rows.  There are no data rows to break.
Message 6 of 8
AHA!
That makes so much sense now.
Is there a way to get the best of both worlds?
formatting and breaking?
Message 7 of 8
Create the data field as a Multi-line text parameter, not regular text parameter, so that you can type in text content in a more humanly manner.  Insert one data row for each numbered note and you can break the table on sheet.  You cannot merger data rows/columns, only header, but I don't see any reason you need to if you use a Multi-line text parameter as mentioned above.
Message 8 of 8
Corsten.Au
Hi
 I think schedules would allow to edit onces places on sheet..
but I can see different schedules behaving differently..
Corsten
Building Designer
