AREA PLAN ISSUES
6 ANTWORTEN 6
Nachricht 1 von 7
craEDQZM
554 Aufrufe, 6 Antworten
AREA PLAN ISSUES
When I create an area plan and make the boundaries I want for each space, I get gaps of white space not being counted, as well as a larger space that is somehow being divided into three areas when I only made one huge area boundary around the room. There is no hidden or turned off lines. I dont understand how this is happening.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: craEDQZM
Be easier and faster to troubleshot if you could post file for us to look at. Can you?
Nachricht 3 von 7
craEDQZM
als Antwort auf: barthbradley
I cannot post firm files publicly, sorry.
Nachricht 4 von 7
Create a new area scheme and new area plans.
Nachricht 5 von 7
craEDQZM
als Antwort auf: ToanDN
Already tried that and it kept doing it.
Nachricht 6 von 7
cbcarch
As a quick test-
Create a new Revit project ( .rvt ) file. Select the Arch Template
 Create (4) walls.
 Create an Area Plan.
Does it work properly? If, so, then something is wrong in your real project.
If not, then perhaps something is wrong with your Template.
 Try creating another new project, with "None" selected for the Template.
Does the Area Plan work correctly?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 7 von 7
Corsten.Au
White areas in Area Plans..White areas in Area Plans..
Corsten
Building Designer
