Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i dont know why this error prevent me to import my csv topography to revit 2025
Your CSV only has 1 column. The CSV should be 3 columns. X, Y and Z.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-35F36FD6-9648-4008-B117-6D7771E5FA9B
actually i have 3 columns latitude longitude and altitude which are x y and z i dont know why you see one column in my excel there is 3 columns
The CSV you posted, and that I opened, does not have 3 columns.
@aymane_azarou wrote:i dont know why you see one column
Perhaps, this is your issue. Me and Revit see 1 column.
do you have any idea how i can fix this problem in excel because it appears to me 3 columns
Are you sure you posted the correct file. Try again.
yes i posted the right file i am sue
can you send me the file from your desktop . i will see if it gonna appear like what you see
Save it as a TXT File (comma separated) and use that TXT file to create TOPO.
This is the Toposolid I get from your data via txt file:
wich one ?
how you transform it into text file
