Project Information of RVT Link
20 ANTWORTEN 20
Nachricht 1 von 21
mustafa_bakrE8NT7
1098 Aufrufe, 20 Antworten
Hello
I have one link in a host file. When I select the link instance it shows me in the Properties Browser a property with name "Project Information" under "Identity Data" Group. I tried to click the "View..." button next to it but nothing happened.
Does anyone know what should have displayed?
20 ANTWORTEN 20
Nachricht 2 von 21
the project information dialog should have displayed:
Your file does not display any information because the project information fields are not filled in.
You can access the project information in the manage tab:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 21
No, I think this is a bug.
The Project Information is populated, though clicking the "View.." button shows nothing. (Not even a message that there is no Project Information)
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Nachricht 4 von 21
als Antwort auf: mustafa_bakrE8NT7
"Edit" should activate Parent Project Information. Check to see if there is a setting in your Revit INI File that controls default behavior.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-9ECD669E-81D3-43E5-9970-9FA1C38E8507
Nachricht 5 von 21
RSomppi
als Antwort auf: Mustafa.Salaheldin
I can confirm this behavior in 2024.
Nachricht 6 von 21
als Antwort auf: RSomppi
Seems to work okay here on 2024, so it's not systemic.
Nachricht 7 von 21
RSomppi
als Antwort auf: barthbradley
I think you need more information in order to say that.
I tested with a cloud project. Not able to test with a network project, I don't have any at the moment.
Nachricht 8 von 21
Mustafa.Salaheldin
I'm on Revit 2023.1.3
¯\_(ツ)_/¯
Mustafa Salaheldin
Nachricht 9 von 21
When i created a new link it also did not work for me.
I am using Revit 2024
Nachricht 10 von 21
RSomppi
als Antwort auf: vitorbortoncello
Cloud project or local? Workshared?
Nachricht 11 von 21
I definitely can say it's "not systemic".   I showed a screenshot proving it.
Nachricht 12 von 21
RSomppi
I'm not going to argue with you about semantics.
Nachricht 13 von 21
vitorbortoncello
Local.
I have several linked models, and they all display project information. However, I tried inserting a new link, and it does not show the project information. I initially thought this was because there was no information in the fields, but even after filling in the fields and reloading the link, it still does not display
Nachricht 14 von 21
I think I see the issue. Was that Link created via a Group in a Project?
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-65356067-C0C6-4239-8580-08111967713F
Nachricht 15 von 21
RSomppi
Not for me.
Nachricht 16 von 21
Mustafa.Salaheldin
@barthbradley yes, in my case it was created from a group, but at the end of the day it is a link, and it should behave normally like any other.
@vitorbortoncello was it same in your case?
¯\_(ツ)_/¯
Mustafa Salaheldin
Nachricht 17 von 21
I agreed with you.  Link it into another Project and the Project Information Parameter will work.
Nachricht 18 von 21
Mustafa.Salaheldin
Yes, when I created a new Host file, it works, but I want to show it in my current project :strahlendes_Gesicht_mit_lächelnden_Augen:
¯\_(ツ)_/¯
Mustafa Salaheldin
Nachricht 19 von 21
Since it's easily replicable, open a support ticket on this "BUG!" through your autodesk.manage.com portal. Let us know what they tell you, if you would please.  Thanking you in advance.
Nachricht 20 von 21
Mustafa.Salaheldin
I'm trying to create a new ticket, but I have issues to login
@barthbradley please try to report this from your end I'll try later during the day.
¯\_(ツ)_/¯
Mustafa Salaheldin
