(solved) locked adaptive pointed not aligned in host family
heichan88
heichan88
(Solve) by lock the face of the joint point, (rather than the point) to , it solved now
I made a pair of joists, the upper joist slides at one end along the lower joist, the junction joint point are locked, but after nested, this junction are no longer fixed and then twisted.
There should be a  error of a simple operation but don't know what it is.
BTW can the warning of "off axis" be ignored and really have no any consequence right?
Please advice, Thanks
heichan88
(Solve) by lock the "face" of the joint point, (rather than the point its self ) to the host face, it solved now
That's not altogether true.  They can appear benign but impact performance - especially if you got alot of them.
Element Is Slightly Off Axis | Revit 2019 | Autodesk Knowledge Network
Yours is an adaptive so you don't need to be too worried about that warning.  If you don't want to see it, just drag a point a bit.
